92' buzzzzzz
  • Thread starter Thread starter misterskin
  • Start date Start date Nov 27, 2008
misterskin
Arkansas
Nov 27, 2008
  • Nov 27, 2008
This is actually on the 1992 2.3 I sold my uncle awhile back, but I figure the same would probably apply to both the 5.0 & 2.3 in this case.
Anyway, Ya turn the key and there are 5 distinct buzzes coming from what seems to b behind the ac controls/radio. it will buzz again, 5 times, about every 30 minutes. If you drive for a few hours....you hear it about every 30 minutes or so. BUZZ, BUZZ, BUZZ, BUZZ, BUZZ............the silence for anoth 30 minutes. The interior lights are cutting off as they should, the wiring has not been assed with......Any ideas? I did make it stop by pulling the fuse that goes to the instument cluster which also disables all of the factory gauges.
misterskin
Arkansas
Nov 27, 2008
  • Nov 27, 2008
and/or......where is this little hidden buzzer, how do i get to it and will it f anything else up if i just clip the juice to it? it's annoying.
MustangLX-5.0
856
Lehigh Acres Fla.
Nov 27, 2008
  • Nov 27, 2008
Is that a beeeep beeeep beeeep beeeep beeeep.........beeeep beeeep.......repeat
That's the airbag control module.Those beeps are a code it's setting off.My '92 is doing the same thing.It sounds faint sometimes.Then goes away an starts...it gets all staticy like a speaker with a bad connection.Mine is a code 52.
Count the first number..then the second.If theres no other codes,there'll be silence for a few extra sseconds then the same code will repeat.Probably bad grounding or a clock spring.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 27, 2008
  • Nov 27, 2008
Does your airbag light come on when you turn on the ignition? Typically, it's a fault with the light, and the control module beeps to alert you of the fault condition, since it's your usual warning indicator of any issues. Without it, you otherwise wouldn't know if there's a fault in the system.
Digital Tuning Airbag Beeping after Holley Dash Install
  • gaslog4
  • Nov 28, 2022
Fox 5.0 Mustang Tech Nov 28, 2022
rednotch
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
C
64 1/2 gen issues
  • corvairbob
  • Jul 29, 2023
Classic Mustang Specific Tech Jul 29, 2023
corvairbob
C
T
PCM Help! No OBD2 communication, cranks but no start.
  • tonymtz1
  • Jun 13, 2019
8K
1996 - 2004 SN95 Mustang -General/Talk- Jun 13, 2019
wmburns
M
1999 Pats,ground or what? Wmmburns?
  • MustangGTTJ
  • Feb 21, 2019
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 22, 2019
wmburns
