92 dash in a 87?
  • Thread starter Thread starter webshot
  • Start date Start date Mar 13, 2006
W
webshot
738
Yay Area, California
Mar 13, 2006
  • Mar 13, 2006
I keep hearing rumors that my 87 dash to 92 dash swap will not work because of some small lining up issues. Has anyone ran into these issues with this swap? And what did you do to make it work? I did a full interior swap and this is the final piece. I have yet to remove the 87 dash, but the 92 dash is all the way out.
W
webshot
738
Mar 13, 2006
  • Mar 13, 2006
anyone?? please
steve-michigan
10
Grand Rapids, MI
Mar 13, 2006
  • Mar 13, 2006
I swapped interiors between my 89 and 92 Fox bodies. I wish I had taken the time to swap IP crossbars because without doing that some of the lower dash attachment screws don't have anything to screw into. However, there are no rattles or misalignments that I've seen.
The biggest hassle is that you'll need to completely rewire the cluster. The cluster circuit is different between airbag ('90-) and no airbag ('87-'89) cars.
V
v8only
2,378
22
49
Mar 14, 2006
  • Mar 14, 2006
When using a 1990-1993 black dash in an 1987-1989 make sure you grab the mounting hardware for the fuse block since the fuse block is mounted differently in 1990-1993 Mustangs. You might need to drill a couple of holes in the dash frame when bolting up a 1990-1993 dash in an 1987-1989 Mustang, but overall it's pretty much a direct swap and is very easy to do.
from my bro's interior swap guide
http://50stangs.com/techarticles/foxbodyinteriorguide.html
W
wazazzle
618
In the dumpster behind McDonalds. WA
Mar 14, 2006
  • Mar 14, 2006
I've answered this question before. Here ya go. http://forums.stangnet.com/showthread.php?t=587022&highlight=dash+swap It should answer all and any possible question you can think of. Search engine can be a great friend if you let it.
V
v8only
2,378
22
49
Mar 14, 2006
  • Mar 14, 2006
I also answered it just above
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
DadLife0724
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
