92 Fox, Tons Of Changes To A Previously Running Car.....no Start, Need Help
Green 94 5.0
2,590
41
Ft. Lauderdale, FL
hurricaneperformance.org
So it's been a really long time since I've posted or even looked here.
I sold my 2 SN95's and my 03 Cobra forever ago and picked up a 92 GT probably 7 years ago now. The car started with a V3 SCi on the stock motor and eventually evolved to an RNH Dart Sportsman 331, AFR 205's, custom cam, Edelbrock Performer RPM/70mm TB, single 3" exhaust into a Magnaflow with turndown, and an On3 base kit. The car ran strong to 15psi however the On3 kit proved to be a "get what you pay for" situation so it came off in favor of bolting the Vortech SCi back on but with pulleys capable of making 17psi. With the blower, the injectors went from 42 to 60, a full Aeromotive Stealth fuel system went in, the TwEECer R/T was removed in favor of a Quarterhorse, an Edelbrock Victor EFI, Edelbrock 75mm TB, Anderson Power pipe, Pro-M 77 MAF, BBK Ceramic longtubes, BBK off road X, and a Bassani stainless 2.5 cat back.
The car cranks and sputters but will not start, hasn't successfully turned over since the tons of changes were made. I have replaced the caps in the EEC, fuel pump primes normally when the key is turned (showing 38psi on the FP gauge), injector pulse has been verified with a noid light, and spark has also been verified. Timing has been set dozens of times, spark plugs are not soaked but do smell like fresh fuel when removed.
MAF transfer is correct, injector slopes are correct, timing is set to base, car has both fuel and spark. What can I still be missing? I'm about ready to yank the motor, carb it, and put it in a Factory Five but I just want to give it one last shot. Ideas? Anyone?
Thank you in advance. I feel like I am missing something simple since the car ran fine with the turbo and now won't even start with only the intake coming off as far as disassembly, just no clue what.
Link to the original thread here: https://www.stangnet.com/mustang-fo...k-and-with-a-new-project-build-thread.838909/
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
17,464
5,627
193
polk county florida
Have you tried a shot of starting fluid?
Run a compression test?
Just shoot'n in the dark here,
Go back over your intake swap procedure, you've missed something.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,685
5,860
204
31
Hillsborough county
Hmm... I have never tuned with quarterhorse however I would be weary of the tune file used. How did you set the maf curve? Is the maf calibrated to anything other than a stock curve?
Boostedpimp
1,043
351
114
NJ
Check compression? Adjust valves? and can you swap a different known good in to rule out the quarterhorse
Green 94 5.0
2,590
41
Ft. Lauderdale, FL
Haven't tried starting fluid. Compression is fine. The car ran perfectly until I stripped it down for the turbo to blower swap. I've been over everything on the intake twice now. It's all there.
The tune file is based on an A9L from:
http://www.efidynotuning.com/a9l2.htm
MAF curve was sourced from the TwEECer included MAF Transfers for PROM24. The meter is a 77mm Pro-M calibrated for 24lb injectors. Injector Slopes in the tune are for 60's. The only other tune change was for CID as its a 331. Fuel pressure at 38 and timing at base (done at least 7 times now).
Going to try swapping the Quarterhorse out for the Tweecer today. Thank you all for the suggestions so far.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,279
2,627
234
74
Dublin GA
lowendmac.com
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Green 94 5.0
2,590
41
Ft. Lauderdale, FL
Thank you to everyone who posted. Work has been crazy the last month and I haven't had much time to look at the car. As of now the front clip and fenders have been removed to let me go over all the wiring thoroughly. More updates coming as I go down jrichker's checklist, hopefully this weekend.
Green 94 5.0
2,590
41
Ft. Lauderdale, FL
I had to take some time off for medical reasons, but I have now been down the checklist. The car had a bad coil and I replaced the distributor with a Cardone OEM replacement just to rule out the PIP sensor. The car still will not start and I am experiencing a condition that is confusing me.
The fuel pump primes, I have 38psi at the rail, 12v on the red injector wires, and verified injector pulse with a noid light. Not a single injector is spraying any fuel into the cylinders. Does anyone have a clue how this is possible with fuel pressure and a verified injector circuit?
jrichker
Mar 10, 2000
27,279
2,627
234
74
Dublin GA
lowendmac.com
Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.80 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct.
Two reasons:
If so then...Nasty problem... you may have dirt in the fuel system...
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles An injector stuck open will release a continual stream of bubbles. Cheap if you have the stuff laying around, and works good too. The same trick works great to find leaking injectors too
Green 94 5.0
2,590
41
Ft. Lauderdale, FL
So after going over everything it turns out the OEM coil went dead also. After changing it I still had a crank and no start issue. After a ton of reading and going over some additional tables in the tune for the injectors the car is actually sputtering as if it is about to start. I am certain my issues are tune related at this point. Getting closer at least!
