I did a KOEO scan today and came up with two a/c related codes - 67 and 79
According to the scanner:
Code 67 - A/C on during KOEO or neutral drive switch open or manual lever position sensor out of range or neutral pressure switch closed or Park / Neutral switch open.
Code 79 - A/C or defrost on during KOEO test.
The car is a manual. I have disconnected the wires from the a/c compressor a while ago as the compressor seemed to be working even when a/c was switched off...
I know nothing about air condition systems, so any input as to what may be wrong or any tests I can perform would be greatly appreciated!
