92 MUSTANG 2.3 HELP !!
FASTTECK
I JUST GOT A 92 MUSTANG WITH A 2.3 IN IT. !!! !!!
THE TACH DOES NOT WORK.?? CAN SOME ONE HELP ME OUT?
WHEN I PUT THE KEY IN AND TURN IT TO THE ON POSITION THE TACH DOES
MOVE BUT WHEN THE ENGINE IS STARTED IT READS ZERO NO RPM'S ?
ON MY 5.0 THE TACH DRIVES OFF THE - SIDE OF THE COIL. BUT I'M NOT SURE WHAT COULD BE WRONG. I KNOW NOTHING ABOUT THE 4 CYL
PLEASE HELP.
check the connections going to the coil packs and the DIS module. if they are all tight then that is a sure sign the DIS is on the fritz and will need to be replaced.
