Hey guys, i'm having some trouble with my 92 5.0 and i'm not even sure where to begin. It isn't my daily driver and it hasn't really been driven in the past 6 months or so. I went to start it today and got NOTHING. Ok so I initially thought it was the battery, so I had it charged. Now when I put the key in the ignition it makes the beeping noise and the dome light is on. It will start up and turn over but then it immediately dies (as if it is not getting any fuel.) I had the fuel pump replaced about 2 years ago, so chances are it probably isn't that. When I turn the key to "on" nothing happens. The fuel pump doesn't prime. The gauges on the dash do not respond, and the radio does not come on. My accessory also doesn't seem to respond to the key either. Basically the only things that work right now are the door locks and headlights. I can't even put my windows down.
I checked the fuses and everything seems to be fine. I also checked the fuel cut-off switch in the trunk and that was pushed down. I'm not very electrically or mechanically savvy so I am asking you guys if anyone has seen or experienced this before. Thanks in advance.
