Replaced coil packs,icm,fuel pump,filter.Whenever the engine is under load it bogs bad.When you mat it it wont rev past 2grand.If you feather the gas it will cath up.I pulled the mass air off while it was running it seamed much better.Of coarse I got a code for this.I do get a lean code also when the meter is hooked up.The meter checks out ok.I'm thinking bad injectors?HELP!
