Electrical 93 5.0 No Injector Pulse
  • Thread starter Thread starter machinermac
  • Start date Start date Jul 26, 2026
  • Tags Tags
    electrical issue fuel delivery
M
machinermac
Minnesota
Jul 26, 2026
  • Jul 26, 2026
Just picked up a 93 5.0 because the seller was not a car guy and just wanted to drive it. I have run down as far as I understand the fuel system pulled the intake and checked fro 12v at each injector all good did continuity test from each injector ground back to the ecu plug all test good. None of the injector wires will flash a noid light. If I have the intake on and shoot starting fluid at it it does run (not perfectly) so I do have spark and timing seems right.
The next previous owner did some mods like a cam and suspension/frame stabilizers but the ECU and fuel look mostly stock. Looking for some direction on where to look to next before I start talking about a new ECU or just installing a standalone.
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Jul 26, 2026
  • Jul 26, 2026
Pull codes:
OBD1 readers are cheap on Amazon or you could pull codes with a paperclip if you are so inclined.
Electrical Thread 'How To Pull Codes From EEC-IV In 86- 95 5.0 Mustangs'
Jan 27, 2016
@Noobz347 - The code dump procedure isn't in the sticky - you may want to add it...
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for...
  • jrichker
  • Forum: Fox 5.0 Mustang Tech
Reactions: Mcmahst
M
machinermac
Minnesota
Jul 26, 2026
  • Jul 26, 2026
Noobz347 said:
Pull codes:
Jan 27, 2016
  • jrichker
As of yet I cannot find a STI or loose cable that should be in that connector anywhere near the self test connector. There is a similar connector near the starter solenoid but its just black wires. I do have a reader but I dont want to fry a possibly good ecu connecting the wrong thing.
AeroCoupe
6,257
4,341
183
Claremore, OK
Jul 26, 2026
  • Jul 26, 2026
My guess is the PIP but need to pull codes first.
Reactions: Mcmahst
M
machinermac
Minnesota
Jul 26, 2026
  • Jul 26, 2026
Was able to trace the line back from the ECU plug it got moved into the STO but when jumpered I get no codes not even 11. Got to do some more testing but if I can't get codes out of it the former owner was screwing with the ECU and it might be shot.
JD1964
there is enough sticking out to grab on to
3,647
1,669
194
Maryland
Jul 27, 2026
  • Jul 27, 2026
Can you hear the fuel pump prime when you turn the key to the run position? The pump should run for a couple seconds and then automatically stop.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Jul 27, 2026
  • Jul 27, 2026
TPS issues can also cause this. Essentially if the TPS returns full 5V sensor ref the ECU will not fire the injectors.
But, sounds like you might have some ECU issues. I second the "do you hear the pump prime" when you cycle the key question
Reactions: General karthief
M
machinermac
Minnesota
Jul 27, 2026
  • Jul 27, 2026
Pump runs continuously in koeo.
DadLife0724
I vote for a new bung hole.
Mar 22, 2024
456
311
73
Cooperstown, PA
Jul 27, 2026
  • Jul 27, 2026
Shouldn't run continuously. I'd pull the ecu and crack it open and inspect it. Look for anything out of the ordinary. Corrosion, swollen and/or loose capacitors. I am by no means an expert at these ECU's but when I opened mine up I found the issue pretty quickly.
JD1964
3,647
1,669
194
Maryland
Jul 27, 2026
#10
  • Jul 27, 2026
  • #10
If you do need an ECU, don’t risk buying a used one. Send yours in to the repair service for exchange
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Jul 27, 2026
#11
  • Jul 27, 2026
  • #11
Continuous pump good sign the ECu need a rebuild. You can likely open it up and take a peek at the capacitors, or test the pin 46 trace
JD1964
3,647
1,669
194
Maryland
Jul 27, 2026
#12
  • Jul 27, 2026
  • #12
Also, considering this car is new to you, you need to make sure which ECU service tag belongs in the car because they are not all configured the same. This includes the possibility that someone re-pinned the harness for a transmission swap. If that was done and the wrong ECU was used, it might explain a failed ECU. You want to avoid installing a replacement and having it fry the moment you turn the key on. The most common service tags are A9L and A9P. I’m not sure which one it is but one is interchangeable with harness modification and the other is not. I think the A9L is the interchangeable one but don’t quote me on that. If I’m wrong then someone please correct me.
JD1964
3,647
1,669
194
Maryland
Jul 27, 2026
#13
  • Jul 27, 2026
  • #13
Here’s the ECU exchange service that some of on here have previously used. I’ve heard no complaints about then thus far
https://ebay.io/m/9o6AEY
AeroCoupe
6,257
4,341
183
Claremore, OK
Jul 27, 2026
#14
  • Jul 27, 2026
  • #14
Direct link to their website is here:
1986-2004 Ford Mustang A9L A9P ECU Repair Service
1986-2004 Ford Mustang A9L A9P ECU Repair Service Engine Computer Repair Please fill out the R&R form here once you've placed your order.ORInclude a note in the box with your order number and vehicle symptoms.A Trusted Product with LIFETIME WARRANTY QUICK TURN AROUND TIMEDomestic and...
www.theecuexchange.com
Lots of us here have used them and they do a good job.
Reactions: General karthief, JD1964 and Mcmahst
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,345
1,561
133
San Diego, CA
Jul 28, 2026
#15
  • Jul 28, 2026
  • #15
+1 on ECU Exchange. I sent them my ECU for no reason, just as an 'insurance policy' to make sure it was fine. Car ran, no reason to, they still found a bunch of stuff wrong and fixed it. Now i know my A9L is good for many years to come.
Reactions: Willybill32, General karthief and Mcmahst
Willybill32
But at least it's tight!
5 Year Member
Jul 16, 2019
643
368
83
Lexington, KY
Aug 1, 2026
#16
  • Aug 1, 2026
  • #16
I second that. I had a tune on my ‘86 and still wasn’t real satisfied. Sent the ECU to ECUExchange and they found and fixed several issues.
Bill
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Electrical 92 Fox 5.0 no start
  • xwhiskeyechox
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 25, 2025
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
  • dan50
  • Jul 18, 2026
dan50
  • brandyn200
  • Jun 20, 2026
AeroCoupe
