  • 1994 - 1995 Specific Tech
93 cobra intake
  • Thread starter Thread starter sage2k
  • Start date Start date Oct 11, 2005
sage2k
645
Baton Rouge, LA
Oct 11, 2005
  • Oct 11, 2005
I won a 93 cobra intake with throttle body on ebay.
What all extra do I need to install this? Should I use the cobra throttle body? I have a 94 gt. I think I need an elbow adapter. What is a good one?
I guess I need gaskets too, which ones and where should I get them?
Anything else I need?
Is there a good pictorial guide to show me how to install this? I never have done it before.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 11, 2005
  • Oct 11, 2005
You payed for more then you bargained for. The cobra intakes come with the EGR built in them. So adding the 93 cobra intake plus the elbow adapter makes it difficult to install. It adds to the length of the throttle inlet making the throttle cable not reach, and the air intake needs to be modified to fit.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 11, 2005
  • Oct 11, 2005
You could always do the Fox TB conversion, since you have two of the key components already.
legalize420
1,541
South Florida
Oct 11, 2005
  • Oct 11, 2005
use the cobra throttle body. i think you will need a few more things for the tb swap. do a search for fox tb swap. the elbow will not be a direct fit as mentioned above. i used felpro gaskets and you should get new intake bolts while your at it. also a good idea to pick up a haynes manual, it can answer most questions you will have.
sage2k
645
Baton Rouge, LA
Oct 11, 2005
  • Oct 11, 2005
Im a little confused. So to use this 93 intake I *HAVE* to do a fox TB conversion?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 12, 2005
  • Oct 12, 2005
No find a way to extend you throttle cable/linkages, move your egr valve tube out more or delete it, and rig your air intake tube to fit. That's pretty much all I can think of right now to make it work.
95COBRA241
339
Delray Beach, FL
Oct 12, 2005
  • Oct 12, 2005
BBK, Edelbrock, and Trick Flow make good elbows. You have to modify the throttle cable bracket to make it reach. You will also need all gaskets. But in the long run I think its easier to use the elbow than to convert to a fox style TB.
94opalgt
358
AKRON,OHIO
Oct 12, 2005
  • Oct 12, 2005
you could always sell it,like im tryin to do with the one i bought.payed 400 for a polished one,found out that i had to modify this or delete that.no thanks,to much bs if you ask me.i bought a tfs track heat with a tfs elbow instead and im glad i did.didnt have to modify anthing.the only thing had to buy was an extension for the egr tube,from 50resto.com.
20new5.0
125
Camarillo, CA
Oct 12, 2005
  • Oct 12, 2005
is it just the cobra intake that you have to do this with, or do you have to do this with all aftermarket intakes for 94-95 stangs?
legalize420
1,541
South Florida
Oct 12, 2005
#10
  • Oct 12, 2005
  • #10
the 93 cobra intake is the only one that is not a direct fit. the explorer intake will work with the elbow along with all aftermarket intakes, or you could try to get a 94-95 cobra upper.
20new5.0
125
Camarillo, CA
Oct 12, 2005
#11
  • Oct 12, 2005
  • #11
oh, ok. I'm buying a Edelbrook performer 5.0 and an elbow adapter. than I shouldn't run into this problem on a 95 stang?
illwood
636
Worcester, MA
Oct 12, 2005
#12
  • Oct 12, 2005
  • #12
Nah, that should be a more or less direct fit.
The intake that provides the most need for doing a fox TB swap is the '93 cobra because the EGR plate was integrated into the upper. The other aftermarket intakes (Edelbrock, Holley, TrickFlow) should work with your existing equipment if you run the elbow adapter.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Oct 12, 2005
#13
  • Oct 12, 2005
  • #13
DO the Swap
RC
RFMustangGT
294
Knoxville,TN
Oct 13, 2005
#14
  • Oct 13, 2005
  • #14
don't worry about peopel saying it won't work. I did it with no problems. yes, things are tight butit works. the only thing is pull out some slack in the t-cable, buy a 93 cobra egr, a cap for your exhaust header, and an elbow. just take your time and you will be ok, you might have to make your own CAI. I had a 94-95 C&L intake and I had to turn it funny to make it fit. If you need anymore help, send me a PM.
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
