93 fox hesitates around 3500 rpm
blufox62
GA
Hey Guys
my 93 hesitates when the cars gets to 3500 rpm. I have replaced the fuel filter, distributor(it was old anyway), cap,button, and wires. if i unplug the mass air flow sensor i still run into the problem. the funny this is that it runs like a champ until i get to the 3500 rpm mark. while hesitating it feels like a governor is installed and the Tach just goes up and down until i shift gears to get the rpms low.
when i ran the codes i came up with a code 91.
anyone seen anything like this? thanks in advance for your help
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
