93 LX: Photo's by request
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
I actually bought this off of craigslist. I've always wanted an *correction, my bad* FOX BODY , since I was teen and figured it was now or never. The guy had to many speeding tickets and had to sell it. This has been an on going project since June.
I'm doing a 15% tint all around next month. I put new Zexius tires on last month, and plan to replace the rims with Cobra R's in December. I'm working from the outside in.
This is what it looked like when I bought it. Since then, I've replaced the following: Starter, Battery, Radiator, Water pump, Serpentine belt tensioner, Timing cover, chain, cover gasket, and valve cover gasket.
I haven't done any interior work yet. However, when I bought it, it had a ripped out stereo and bad speakers. Since then I've added, a JVC CD/MP3 Deck: IPOD ready, Two 5x7 Infinty Speakers in the rear, and Two Rockford 10's Subs w/975 Watt Amp.
Damn ashtray & ashtray door.
jinx369 said:
I've always wanted an F-Body, since I was teen and figured it was now or never.
Um no, F-Body is a Camaro/Firebird
Fox Body is a Mustang... :D
The ashtray door is a simple fix, I fixed mine with a small bolt, nut, two washers, and even used JB weld to attach the rubber piece that goes on the E-brake slot.
If you can't figure out the ashtray door fix with a few homedepot hardware pieces, here is a lazymans solution.
http://www.mavromont.com/MMIp/ISB_01/ISB01_Info.htm
Looks good. I like the look of LX hatches with Saleen wings....well because that's what i have.
Not sure i like the wheels. They look like the wrong offset and look sucked under the body, esp in front. You prob get rub huh? Good call changing to Cobra R's. Will look much better.
