93 Mustang
  • Thread starter Thread starter 93Notchback93
  • Start date Start date Jun 16, 2016
93Notchback93
20
  • Jun 16, 2016
what should my air fuel ratio and water temp be at while I'm driving?
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 16, 2016
  • Jun 16, 2016
Your "normal" AFR would depend on if you are naturally aspirated or boosted? Your temp kinda depends on what temp thermostat you have installed and if you're reading off the dash NORMAL gauge or an aftermarket gauge?
93Notchback93
20
  • Jun 16, 2016
Naturally aspirated l, mine is after market it usually reads like 210-230F
93Notchback93
20
  • Jun 16, 2016
The one in the dash is usually all the way towards the top and the aftermarket water temp one I have is like 210-230F.
I have 2 dual fans in the front aswell
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 16, 2016
  • Jun 16, 2016
Normal range for AFR I believe is between 11.x-14.x. Your temps shouldn't exceed 200* IMO. What temp thermostat do you have installed? What temp do you have your fans setup to turn on at? What fan controller?
93Notchback93
20
  • Jun 16, 2016
The fans are on as soon as the car starts.
stykthyn
5,232
2,652
223
gainesville
Jun 16, 2016
  • Jun 16, 2016
I would think 210 would be the hot side of normal. Anything over that and you have cooling issues. 230 is definitely pushing your safety net.
93Notchback93
20
  • Jun 16, 2016
I also got phantom ii auto meter water temp guage
stykthyn
5,232
2,652
223
gainesville
Jun 16, 2016
  • Jun 16, 2016
Any chance you can put the stock clutch fan back on?
93Notchback93
20
#10
  • Jun 16, 2016
  • #10
I just bought the car like this a couple weeks ago
stykthyn
5,232
2,652
223
gainesville
Jun 16, 2016
#11
  • Jun 16, 2016
  • #11
I would try to burp the cooling system to see if there's any air trapped inside.
93Notchback93
20
#12
  • Jun 16, 2016
  • #12
How would I be able to do so, Could you please explain. I'm not too familiar with this kinda stuff
Thanks alot
stykthyn
5,232
2,652
223
gainesville
Jun 16, 2016
#13
  • Jun 16, 2016
  • #13
Jack the front of the car up so the radiator cap is the highest point. Turn on the heater and remove the rad cap. Start the car and let it run. When the thermostat opens any air trapped inside will be forced to move upwards and exit out the cap. Keep an b eye on your engine temps.
93Notchback93
20
#14
  • Jun 16, 2016
  • #14
Ok I will try that and one thing I noticed in my engine bay is lots of white splash marks, seems to be some sort of oil ? There is no leaks or anything but I was warming it up and revved to like 5000-6000 rpm? Where could that came form
stykthyn
5,232
2,652
223
gainesville
Jun 16, 2016
#15
  • Jun 16, 2016
  • #15
No clue. Snap a pic?
93Notchback93
20
#16
  • Jun 16, 2016
  • #16
Sent
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
  • dan50
  • Jul 18, 2026
dan50
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
