  • 1994 - 1995 Specific Tech
94-95 overheating
  • Thread starter Thread starter sickponey
  • Start date Start date Aug 6, 2009
sickponey
  • Aug 6, 2009
I just got my heads back form the machine shop and re did the head gaskets. i have a 3 inch aluminum raditor a 2 16 inch fans a 160 therm. with the holes in it i retarded the timing and its still doing it any ideas?
393strokervert
340
florida
Aug 6, 2009
  • Aug 6, 2009
overheating
new thermostat? try it w/out the thermostat, maybe it's
sticking. how old is your water pump? it could be going bad.
HISSIN50
34
129
Aug 6, 2009
  • Aug 6, 2009
When does it overheat? At speed or while idling?
How hot is it getting?
sickponey
  • Aug 6, 2009
the thermostat is the newest of three. i also drilled the bypass's in it. the water pump is also brand new on it.
sickponey
  • Aug 6, 2009
its over heating at idel havent even been able to test drive it yet. and if i let it go it will go all the way past normal at H
393strokervert
340
florida
Aug 6, 2009
  • Aug 6, 2009
is it remotely possible that the water pump is for a non serpentine system & therefore would be spinning backwards & not pushing water? or possible that temp sending unit could be bad? might sound like stupid ??? but just trying to help.
HISSIN50
34
129
Aug 6, 2009
  • Aug 6, 2009
If the gauge reads hot so quickly that it doesn't seem possible, consider that there's air in the system.
True 5.0
237
Southeastern Wisconsin
Aug 6, 2009
  • Aug 6, 2009
Is the fluid level dropping in the overflow tank? If so, you may have a bad gasket or hose somewhere. Did you pull the engine out? Check the block to body ground strap. I broke my strap during an engine swap and had all sorts of strange readings before I added a new ground strap.
393strokervert
340
florida
Aug 6, 2009
  • Aug 6, 2009
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
H
Brand New Built 302 overheating
  • hassler
  • Sep 26, 2025
Rcdgl
R
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
