94 cobra sway bars...
The rear bar will bolt up no problem.
The front may not work as well...SN95 cars had a wider front track than the Fox mustangs, so the swaybars mounted further out on the control arms. You should be able to run it, it'll just be a little goofy on the ends and might rub the tires at full lock.
the rear will fit and front WILL NOT! but you wont really gain anything from the rear one it is hollow, they break! just buy stock 5 liter sway bars front and back and you will be happy with how big a differnce they will make
