'94 GT Fuel pressure woes
speedfreak94
Hello StangNet Community:
I'm hoping someone on here can help me with a fuel pressure problem...
This past Friday my '94 GT broke down on the side of the road for the first time in nearly ten years of ownership. I crossed a bumpy intersection and didn't make it to the other side before the car went dead. It happened immediately without a cough or sputter and all systems seemed to be a GO other than the fact I had no fuel pressure! The pump wouldn't prime and I checked the fuses and inertia switch.
I went through the car with a multimeter Saturday (after taking the walk of shame with a tow truck) and found 11.7 volts at the fuse box under the hood, 11.7 going into the CCRM, but only 1.1-1.8 coming out on the green line with the yellow stripe that leads to the inertia switch (for some reason it seemed fluctuate about every 5 seconds).
I thought I had nailed it down to the CCRM and didn't think much of it since there's slightly over 200K on the car. However after putting another one in, still there is nothing. I can jump the pump on the CCRM pigtail and the pump fires right up. And after a few minutes of playing with the multimeter again, I'm now seeing that the pigtail for the inertia switch is still registering a solid 1.9 volts--with the CCRM unplugged!
I'm confused beyond words, and trying to get the car ready for the Power Tour this weekend. The car has been rearended once (that's how I picked it up nearly 10 years ago) and does have a 255 lph intank pump w/Aeromotive adj. regulator (installed nearly 4 years ago). Like said before, this car has been excellent to me over the years. If you have ANY ideas, I'd be more than happy to take your advice!
Thanks Everyone! :nice:
I took a look at this to see what I could figure out.
Now I'm not expert on reading diagrams and I don't know how much voltage the CCRM is supposed to be putting out to the inertia switch (I would imagine right around 12v), but it looks like the voltage you are seeing in the wire could be coming from the PCM.
Was the CCRM a known good replacement?
My thoughts would be if you are able to jump the pigtail and you can get it to fire up is either in the PCM or CCRM. I'm sorry I can't be of more help. We have some electrical gurus who may be able to shed some light on this. Good luck and I hope you can get it fixed for your weekend, I've been in that boat before.
EDIT: 2 more links that may be helpful to you:
Here
And Here
