  • 1994 - 1995 Specific Tech
94 Gt Need Help!! Car Won't Start Unless Ether Is Sprayed :(
  • Thread starter Thread starter BruisedGT50
  • Start date Start date Sep 24, 2012
First Prev 2 of 2
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 25, 2012
#21
  • Sep 25, 2012
  • #21
Bad PIP in your distributor. I'd put money on it if I were a betting man. Have anyone with a 94-95 that you could swap distributors with for half an hour?
BruisedGT50
14
Marion, Il
Sep 25, 2012
#22
  • Sep 25, 2012
  • #22
The car is getting 38 lbs at the rails, has new sparkplugs and wires and is getting very good spark, she has few thinks wrong in this post that I will clear up 1st the car at this point if you spray starting fluid in filter it will fire up and runs VERY WELL on its own with continueing to spray you can drive it all over without problems unless you turn it off, if you start it back as soon as you kill it 5 out of 10x it will fire back on its own until it has set for few mins or longer then its hit or miss. I have literilly been over everything and went as far as disconnecting wiring plugs and cleaning and reattaching them. Dont remember exact codes but nothing out of ordanary smog ect. and cleared the codes. All grounds have been checked cleaned and replaced, everything has checked out and the car runs perfect once you help it start other then the occasional start it up or turn key one and windows, Radio, windsheild wipers wont work turn off back on they work. Think its has a wire gremlin somewhere just dont know where and I believe the window ect. problem is seperate from the starting problem. main juntion box under hood has been check and cleaned as well...
BruisedGT50
14
Marion, Il
Sep 25, 2012
#23
  • Sep 25, 2012
  • #23
I replaced Distributer I thought same thing it was acting like it was out of time upon tryn to start but wasnt the issue..
BruisedGT50
14
Marion, Il
Sep 25, 2012
#24
  • Sep 25, 2012
  • #24
I meant without continueing to spray starting fluid u only need to spray it until it starts then runs completely on its own
Admin Dude
Jan 4, 1985
43,351
21,548
234
Box behind Walmart
Sep 25, 2012
#25
  • Sep 25, 2012
  • #25
This description here sounds like an ignition switch. LRS (I think)has one that's NOT made in China. Have you taken the column covers off and laid eyes on the switch? Look to see if it's separating or tired looking.
BruisedGT50
14
Marion, Il
Sep 25, 2012
#26
  • Sep 25, 2012
  • #26
Yes I have checked that plug cleaned it as well and all plugs in the area, but the ignition was replaced not to long ago with one from O'Reily's and problems started after that, but they didnt come on all at once, ran fine right after then everyonce in awhile would take forever to start but wasn't very often then more and more until we are here at this point
Admin Dude
Jan 4, 1985
43,351
21,548
234
Box behind Walmart
Sep 25, 2012
#27
  • Sep 25, 2012
  • #27
I think it's time to swap it again... at least long enough to verify or rule it out. O'Reileys (any of the parts stores for that matter) switches are Chinese garbage. Ask me how I know.
BruisedGT50
14
Marion, Il
Sep 25, 2012
#28
  • Sep 25, 2012
  • #28
Ok will try that and let you know thanks
Admin Dude
Jan 4, 1985
43,351
21,548
234
Box behind Walmart
Sep 25, 2012
#29
  • Sep 25, 2012
  • #29
You can also use this to start checking for power.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 25, 2012
#30
  • Sep 25, 2012
  • #30
Screw it it might just be that. Depending which slider in the switch fails first a multitude of things could randomly stop working. I just didn't think the spark and fuel pump could run without the computer. The CCRM which controls fans and the pump are controlled by the computer. No ignition power to the computer and i doubt everything BUT the injectors would work. (Sorry about playing devils advocate on my own post, its how i process eliminate)
Admin Dude
Jan 4, 1985
43,351
21,548
234
Box behind Walmart
Sep 25, 2012
#31
  • Sep 25, 2012
  • #31
I'm thinking a lot of the same things you are... That ONE post though... stinks of bad ignition switch. Including weak ignition system symptoms.
BruisedGT50
14
Marion, Il
Sep 25, 2012
#32
  • Sep 25, 2012
  • #32
Sorry for the misinformation in earlier posts guys I was going off bits and pieces of things I was being told, I am going to order a new switch now and have him replace that ASAP.....fingers crossed that this is the simple fix after all
toyman
1,944
54
79
Vernon BC
Sep 25, 2012
#33
  • Sep 25, 2012
  • #33
BruisedGT50 said:
No codes were reporting when we scanned after parts where put on, I do not have a personal code scanner so I was taking it to O'reillys after replacing parts and no codes were showing
I wouldn't be surprised if they plugged into the OBDII port under the dash and not the OBDI one on the passenger side strut tower.
toyman
1,944
54
79
Vernon BC
Sep 25, 2012
#34
  • Sep 25, 2012
  • #34
Admin Dude
Jan 4, 1985
43,351
21,548
234
Box behind Walmart
Sep 26, 2012
#35
  • Sep 26, 2012
  • #35
Wait... you were joking, right?
toyman
1,944
54
79
Vernon BC
Sep 26, 2012
#36
  • Sep 26, 2012
  • #36
The dash OBDII port is for the 3.8 engine. The engine bay OBDI port is for the 5.o. Ford shared the same harness for 94-95.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 27, 2012
#37
  • Sep 27, 2012
  • #37
Maybe he has an A9L, A9P in there lol
First Prev 2 of 2
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
02 mustang gt crank no start
  • 2v.cjmullis
  • Jan 28, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 30, 2026
