94 gt parts and car
Highoutput5.0
17
RI
selling mostly everything from my 94 gt to buy another car.
buy the car as a whole for 4800.00
or the parts out of it.
Black 1994 gt.
No A/C
No smog pump/
Trickflow street heat heads
Harland sharp roller rockers with arp studs and guide plates
Arp cylinder head studs
Manley pushrods
F303 cam
Professional products typhoon intake and throttle body
Tweecer tuner.
T5 transmission
3.73 ford racing gears
svo side skirts for side exhaust. currently has dumps though
no cats
BBK long tube headders ceramic coated.
Steeda ultra light silver 5spoke with falken tires shaved
chrome 04 cobra wheels with or without like new coopers
cobra RR hood not on car needs a little fiberglass work. not bad though
factory cobra R hood on car
kirban adj fuel pressure regulator
24lbs injectors (ford racing)
trickflow aluminum valve covers with custom tig welded moroso breather
msd 6al
msd blaster coil
ford racing wires. RED
new stock radiator
I AM FORGETTING STUFF. ASK me about other stuff you are looking for.
THE CAR RUNS AND DRIVES SEE IT RUN IF YOU WANT THE WHOLE MOTOR OR TRANS OR ANYTHING YOU WOULD LIKE TO SEE RUNNING FIRST. IT WILL BE MY DAILY DRIVER UNTIL PARTS ARE BOUGHT.
Most parts were new last summer. Less than 5000 miles put on it since then. No nitrous or boost put to it. new rings and bearings in motor
Contact me on my cell phone if you would like. 401-578-7885. (sam)
how much for the heads? and what size are they? 165s? Also, are they cast iron or aluminum?
The heads are Trick Flow Twisted Wedge aluminum heads.
61cc combustion chamber
2.02" intake valve
1.60" exhaust valve
No O-ring grove for loc wire gaskets
almost anyone will agree with me in saying these are one of the best street heads you can possibly bolt onto a stock short block 5.0. every dyno test i have seen they perform better than edelbrocks performer heads and AFRs 165 heads
$900 for the heads the way they are with arp rocker studs left on them. OR
$1200 for the heads, arp head studs, arp rocker studs with perma locks and harland sharp orange 1.6 full roller rockers with a set of manley pushrods length matched for this setup.
Also just wanted to let everyone know I am a currently a ford tech at Flood Ford of East Greenwich R.I. and am also part time at Ocean State Performance. If you are hesitant to buy my parts because you need somone to install them. There is a good chance we can work something out. Thanks
