94 gt Will not start after running
mustang_gt302
New Jersey
I have a 94 GT that will not turn over after running. I can get it started be giving a little gas but if I take my foot off it will stop running. If I wait 5 or 10 min it will start with no problem and run great. If i keep my foot on it to keep it running i can feel the rpm go up little and I know it will stay running after that.
Thanks
Run codes and consider that your IAC went south or is dirty.
Only clean the IAC if you're prepared to buy a new one, as they sometimes go south after being cleaned.
Good luck.
The fuel fiter is new. I can hear the fuel pump go on when I turn the key. The car does not stall driving. I read that it might be IAC and I cleaned that with an engine cleaner. I might get a new one this week it sound like the problem. It use to happen at outside temp. at 90F and higher but now it does it at cold temp too.
Thanks
Thanks
check your dist. i had same problem if its old dont hurt either way also check fuel pressure.who was looking for a 95 5,0 harness i got old one
