94 gt
ChrisDiehl77
GA
I bought a 94 gr8 about 4 years ago and I'm ready to do some work to it. It has some aftermarket parts installed already. My question is how can I figure out what size injectors it has? It has a trick flow plenum. (I guess that's what it's called. Big thing on top of engine). I'm assuming it has a 75mm throttle body. And how can I tell the gearing in the rear? Guy said it had gears but didn't tell me anything else. This was 4 years ago also. And is there a way to tell how much it has been lowered? It has strange shocks in the rear. Not sure about up front. Thank you
Get a repair/assembly manual, check ebay or motorbooks.
This link will help you id the injectors http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Google a pic of a stock mustang same year and compare it to yours
As for rear gear you can jack it up, use jack stands, if you or a friend get squashed because you didn't use stands will get you booted from here:rolleyes: mark the drive shaft, spin the tire 10 times slowly, count driveshaft rotations, this will give you an idea of gear ratio, I think you could spin the wheel one full rotation and get the same results but it's more fun for your friend to try to count that many times,
