95 5.0 is super slow! Why? Please help!
mattyurdaddy
dallas
HI!
So I just picked up my first 95 5.0 covert, AODE. The car sounds great with the single chamber flows, x-pipe, and NO CATS , but has abosolutly no get up and go. So I started with the basics. I replaced the cap and rotor, spark plugs, and fuel filter. It still wont even break traction from a zero punch. I know the car isn't going to be screaming fast as stock as it is, but it should have some more umpf. When driving it, I will punch the gas and the motor is slow to wind up, the transmission kicks down and then doesn't accelerate like it should for being in the lower gear, but sure gets loud when the rpms go up.
A few things to consider..?
-I replaced the plugs, the old ones showed signs of running lean (white tips.)
-When I removed the old fuel filter, it wasn't under a lot of pressure. ( I thought that fuel injected cars would be under enough pressure to spray gas out everywhere, instead it just dripped.
-NO CATS?
What do you think?
Can't really answer your question without knowing history of car. Assuming all is good (sounds like it), here is my experience with stock automatics. Won't spin by just punching the gas. Had a '90 LX 7up auto and the stock gearing was awful for bottom end. Passing gear was great...take off not. Look at changing the rear end gear. That's my 0.02 without knowing the car. Others will tell you the mods to make to get you where you need to be. I've left all my cars stock except for the '65 I'm working on now. The 90GT 5 speed is bone stock with only 14,400 original miles on it. She's a beauty.
The problem is I hear a lot of "like it should", etc. etc.
What are you expecting exactlya nd what do you have to compare it too?
My 95 Auto vert isn't all that quick either. It gives a little stuff in the seat and it's fun, but it won't break them loose from a stop, and it's not all that fast. I think they ran15's to 16's in the 1/4 stock. Verts aren't the lightest cars around and the gearing isn't exactly for go when stock.
If you wanted fast, you should have gotten a gutted tin-top. :shrug: Drop tops sure are nice for a cruiser though. :D
yea gears is a must. 3:73's or some 4:10's will really give you a punch. Stock aods are dogs. Might be a good idea somewhere along the line to do a shift kit and converter in that thing. It takes money...
95 gt
Gears are a must. I have a 94 5speed with 3.73 gear, aluminum driveshaft, and other mods to engine. The gears and the driveshaft really freed up horsepower. You will need a speedo tooth gear. Let me know, I have an extra one for the 3.73 if you go with it.
Generally the rule of thumb is that in a 4spd AODE you want a numerically higher gear. INstead of 3.73's you should go with 4.10's. I have 3.73's in my car and it made a world of difference and i still pull 25+mpg on the highway @ about 2500 - 2600 rpm at 75-80
Find out what shape the engine is in before you start chasing rabbits and spending money.
Do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading.Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
Dump the codes and see what the computer says is wrong… Codes can be present without setting the Check Engine Light.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
WalMart may have the above LCD display scanner for less than $35.
Post the results and I will try to help you fix any codes you get.
Compression is good and no codes: then look at some of the other items already suggested.
