95 cobra t5 into93 fox
TOOLOW91
8,762
234
S.I.NY
Can't get a straight answer no matter where I search so what do I need to get a 95 cobra t5 into my 93 the bellhousing and starter , or can I swap iNPUT shafts ?
Well, you could swap the input shaft, but you'd need to find an input shaft from a 1993 Cobra as the 93-95 cobra t-5 use a unique pocket bearing that the typical t-5 doesn't use.
You could do that as well. 94-95 v8 bell housing..unsure if you need the clutch fork.
Keep in mind this pushes the trans back 3/4" so shifter hole might need to be trim and you may or may not need to shorten the driveshaft.
