Expired 95 Gt (cobra Clone) Bennett Racing Dart 348 Motor, Built Trans Project Car
95 GT Cobra Clone (Needs Paint!)
Short version (everything listed below is new and never ran, some still in box, a lot just bolted on)
Engine
348ci 4.125 bore Dart Sportsman Bennett built short-block never fired up or ran
TFS Hi Ports stage 3 port also by Bennett
with TFS Box R port matched to the heads
Harland Sharp RRs
Harland Sharp stud girdle
Fabricated Valve covers
90mm Accufab TB with spacer.
Meziere Elec water pump
ATI Balancer
Comp Cams 5/16 pushrods
FMS Hyd Roller Lifters
Canton Oil Pan w/12AN bung welded in for turbo oil return
Trans
Silverfox built 1000hp Ultra 4r70w (actually using a 4r75w) with lockup OD and trans-brake
Dirty Dog 9.5" 4000 Stall Converter
Rearend
95 8.8 (used my factory 8.8) with 9" flanges (early big ford ends) narrowed 3.25" per side
Chromoly 1350 pinion yoke, 35 spline axles, 3:55 gears Nice custom bracing, powdercoated
Suspension
UPR Chromoly K-member, A arms, 4 bolt caster camber plates
Strange Drag Brakes front and rear, braided lines for front.
Flaming River Manual rack
UPR Double adjustable uppers
UPR Single adjustable offset lowers without spring perches
UPR Double Anti-Roll bar
QA1 rear Adjustable coil overs
Wheels
Bogart Fronts 15 x 3 1/2 - 165R15
Bogart Rears 15x11 4.25 BS - 325x50x15
Chassis
Mini-tubbed
Chromoly cage (main hoop back)
Car needs paint and carpet. Interior is Grey and Black. A few gauges and a tach
Chassis and rearend built by William Bodley (same shop who built Duck and Amanda's Car)
"76mm HP Turbo kit" (bought new and USED for maybe two weeks on my old stock motor but SOLD the turbo, waste gate and injectors)
**** so basically cold/hot side plumbing and intercooler and C&L MAF****
A build up thread located at the Corral.net in the Drag racing forum Titled Just a little update and a few pics of my buildup started by Adrenalin if the link below doesn't work. Lots more detailed info there.
http://forums.corral.net/forums/drag-racing/909885-just-little-update-few-pics-my-buildup.html
I tallied up all of the receipts that I could find, and I know that I don't have all of them, which totaled 30k not including the cost of the car, wheels (I think) and a set of Corbeau's.
Please check out the link above fore more info.
Adrenalin302
at
hot mail
dot
com
Call or text
863-255-5982
Will NOT part out anything
Price is 19,500 OBO
