Expired 95 Mustang Project- Roller Motor/trans & More
95 GT Cobra Clone - Needs Paint & Carpet - Unfinished Project Car
Basic info (everything listed below is brand New and never ran, just bolted on unless otherwise noted)
Engine
348ci 4.125 bore Dart Sportsman Bennett built short-block never fired or ran
TFS HiPorts stage 3 port also by Bennett
TFS BoxR port matched to the heads
Harland Sharp RRs
Harland Sharp stud girdle
Fabricated Valve covers
90mm Accufab TB with spacer.
Meziere Elec water pump
ATI Balancer
Comp Cams 5/16 pushrods
FMS Hyd Roller Lifters
Canton Oil Pan w/12AN bung welded in for turbo oil return
Trans
Silverfox built 1000hp Ultra 4r70w (using a 4r75w) with lockup OD and trans-brake
Dirty Dog 9.5" 4000 Stall Converter
PA Flexplate
Rearend
95 8.8 (used my factory 8.8) w/9" flanges (early big ford ends) narrowed 3.25" per side
Chromoly 1350 pinion yoke, 35 spline axles, 3:55 gears Nice custom bracing, powdercoated (Shock mounts added later)
Suspension
UPR Chromoly K-member, A arms, 4 bolt caster camber plates
Strange Drag Brakes front and rear, braided lines for front.
Flaming River Manual rack
UPR Double adjustable uppers
UPR Single adjustable offset lowers without spring perches
UPR Double Anti-Roll bar
QA1 rear Adjustable coil overs
FMS Aluminum Drive Shaft -used
Wheels
Bogart Fronts 15 x 3 1/2 165R15
Bogart Rears 15x11 4.25 BS - 325x50x15(tires are used)
Chassis
Mini-tubbed
unfinished Chromoly cage (only the main hoop back)
Car needs paint and carpet. Interior is Grey and Black. A few gauges and a tach
Chassis and rearend built by William Bodley (same shop who built the Ducks and Amanda's Car)
"76mm HP Turbo kit" -bought new and USED for 2/3 weeks on my stock motor but SOLD the T4turbo, waste gate and injectors
-so basically cold/hot side plumbing and intercooler and C&L MAF
88mmGT47.96AR ball bearing turbo is what I have to replace the above turbo that was sold. (mods needed to the kit for this to work) hot side ceramic coated
Detailed build w/pics:
Click >> Corral.net build thread
Lots of pics here:
Click >> Pics on Photobucket
I tallied up all receipts that I could find, & I know I don't have them all, which totals 30k not including cost of the car, wheels (I think) and a set of Corbeau's- used.
16,500
Adrenalin302
hot mail
dot
com
Call/text
ate63-too55-59ate2
Thanks Terry
