95 GT dangerous situation
realtex
5 Year Member
Dec 3, 2018
21
tx
After filling up, I noticed some gas on the ground. I thought it was overflow. I looked under the car, and gas was pouring out. To make a long story short, there is a gasket between the filler neck and tank, which failed. Had that happened on the highway at 75mph, well, I don't want to think about that. Check that gasket NOW!
Reactions: General karthief
Reactions: limp
You can buy a 2 pack on Amazon for $10 or you could, was identical to the Dorman and spectra ones I had. .. They should be replaced any time you drop the tank. Its just a rubber seal. I ve seen cars that leaked for years, ppl globbing rtv around them etc its common on a lot of cars beside just ours... There pretty much one time use since its narrower then the fill tube to seal it..
