95 mustang wheel bearings, bearing made in hub?
tiptopss
48
want to replace the front wheel bearing on my 95 mustang, but im unsure if the hub and wheel bearing are all one peice, or is the bearing seprate from the hub, thanks alot
Just did this a while ago. The hub and bearings are one piece. It's held on with one nut under the round dust cap. The torque on that nut is pretty crazy, 258ft/lbs. You'll need a special ratchet to crank that down, or just tighten it as much as you can with an impact wrench. If you're near Los Angeles, I can lend you the torque wrench you'll need.
Be sure to buy new hub nuts and dust caps. You're not supposed to re-use them, and they're cheap to buy anyway.
