I have a 95 mustang 5 speed with 75K miles, & the following mods:
Edelbrock intake
underdrive pulleys
70 mm TB
cold air intake
smog pump delete
exhaust (from the factory manifolds back)
Alum. Drive shaft
4.10 gears
Boxed control arms
Holley 155 fuel pump
I plan to install the NOS super power shot (wet) kit that was on my non-EFI chevelle.
I plan to purchase a soft plume nozzle and install it in my CAI.
Is my fuel pump (Holley 155) capable of handling 100 shot?
Do I need an adjustable fuel pressure regulator?
Where should I set my timing? Total timing??
What spark plug should I use?
Is a fuel pressure safety switch needed?
Is any ignition upgrade necessary?
Any computer modifications need?
Yes, I did search old forums, but didn't find answers to all of my questions.
Also, I will have a bottle heater, and will run a wot switch.
Thanks!
Edelbrock intake
underdrive pulleys
70 mm TB
cold air intake
smog pump delete
Alum. Drive shaft
4.10 gears
Boxed control arms
Thanks!
