  • 1994 - 1995 Specific Tech
95gt radiator problems.. PLEASE HELP!!
  • Thread starter Thread starter r_suh
  • Start date Start date Jun 22, 2005
R
r_suh
17
  • Jun 22, 2005
Hey guys i have come to u again for advice. I have a 95 gt and i have experienced the heater core failures as well as many rad failures.. this morning when i started my car up i noticed my low coolant light coming on.. so i added coolant/water mixture of 50/50 and filled up the resevoir tank. but when i got under the car i noticed a few drips of coolant.. now this isn't the first time this has happened to me. this is my THIRD radiator that i have replaced on my car in a time span of about 5- 7 months. in that time the same pinhole leak has happened. i'm not too sure if sn95 mustangs have radiator problems or not but i'd like to hear everyones input as well as what you guys have gone through with rad problems. i have also gotten the recall for the radiator fan done as well. and i have been hearing about electrolysis being a possiblity of pinhole leaks. if you guys have any ideas please let me know!!
The car is still drivable and doesn't overheat. just leaks drips of coolant.
94-302-vert
1,947
NE CT
Jun 22, 2005
  • Jun 22, 2005
When you changed the radiators did you flush the system?
I was amazed at what came out of my cooling system when I flushed it and rinsed out the overflow tank last week.
R
r_suh
17
  • Jun 22, 2005
no i didn't. but i guess today i should. i'm going to get it checked today but would still like everyones input on this. Anyone know of electrolysis??? this is very new to me and would like to absorb as much info on this as i can.
BULLITTSTANG95
97
Oklahoma City
Jun 22, 2005
  • Jun 22, 2005
if you are doing a stock replacement i would suggest just getting rid of it.... the side tanks seem to leak a lot since they are just plastic tanks with a gasket in between. i would suggest getting a good aluminum radiator. just my 2 cents
LoudToy958
435
Bremerton, WA
Jun 22, 2005
  • Jun 22, 2005
I have heard a few people go on about the elctro problem, but I don't see it causing so much damage to a part that is not really touching any metal at all. It should be held in by rubber boots all the way around.
IMO you are just having my kind of bad luck. I went through three starters in two months. I only put 95 miles on my car in those three months. Just one of those things.
I agree with the upgrade to a aluminum comment made here. I don't think they keep your car cooler, but they do take longer to heat up, and cool down a lot faster than the factory unit.
Hope you get this solved, you could always check all the grounds on your block to ensure all is well. Or add a few grounds if you deem in neecessary.
Wish I could be of more help on the issue............
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
