96-02 camshaft specs
what do you mean by the specs, only reason im asking is cause i have the 96 shop manual. (like cam caps are tighten at 8-12 Nm or 71-106 lb-in.) let me know if i can help in some way with the book.
96 Spec is the most agressive, if you read the mags the fastest moct powerful N/A mos guys are runnung 03/04 cobra blocks with 03 Cobra heads Mach intakes and 96 cams (just polished) and making 475rwhp and 370 rwtq. I have read several articles about the best cams being the 96 grind. Just the casting is ugly and helps to polish the lobs:shrug: They said they had tried all the stock cams and alot of custome grinds and said this is the besdt combo. Shown Johnson with the points title in N/A 4.6 Factory Stock class. (May 07 5.0 issue page 202)
