  • SN95 4.6L Mustang Tech
96-98
  • Thread starter Thread starter modular
  • Start date Start date Apr 27, 2004
M
modular
26
  • Apr 27, 2004
I was wondering what would a 96-98 stang out out with these mods?
stock p.i. heads, stage 2 vt cams, p.i. intake, accufab plenum,75mmtbody,87mm maf,k@n cold air,190lph pump,autologic chip,full msd ignition,underdrive pulleys,full length headers,hi flow xpipe, and aftercat exhaust.
M
Mod Man
77
  • Apr 27, 2004
If you are wondeing how good it would run. The are would run pretty strong. But with the stage 2 VT's cams......They are awesome sounding..just got done putting them in an 98 GT (Customers car), You will need to get the Comp cam Behive springs to use with tthem. I would also recomend porting the heads while they were out. That will only help the hole setup work a little bit better. But yeah. That would be a good setup for an N/A setup. The car should make (With heads ported) around 300+RWHP. Let me know if you need any prices. But that would be a good way to wake that old Mod Motor up. Strong setup for sure. And those cams sound wicked. Good luck.
M
modular
26
  • Apr 27, 2004
Thanks.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
K
WTB/Trade Looking for a set of 96/98 Cobra Cams
  • KEVINS
  • May 1, 2023
  • Engine and Power Adder Parts
Engine and Power Adder Parts May 1, 2023
KEVINS
K
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
