96 Gt Ground Locations For Alternator!!! Plz Help
Williamhorse
i just bought a 96 GT i thought i had a bad alternator and i bought a new one and a new battery but the Battery gauge is reading Low so i guess the alternator is still not charging the battery i need to find out where all the grounds are for this car any one can help plz!!! Also when i was put the wires back on the new alternator the one wire didnt seem to click in it might be broke? its the little clip wire in the middle!!
More than likely, you found your problem with that wire. There are two grounds near the battery, on the radiator support. The other ground is from the driver side motor mount to the frame.
The Wire Still Goes in but just not Tight and i checked the Rad Support Already that didnt help at all But the other one all the way on the right side? and i read that theres another on the engine block?
The only one I know of is from the driver side(left side) motor mount to the frame behind the left front tire. I've never seen any other grounds other than these. Have you taken the alternator back to the store and had them check to make sure it's good? I've seen bad alternators off the shelf.
