  • SN95 4.6L Mustang Tech
97 Cobra ball joints
  • Thread starter Thread starter roxtro
  • Start date Start date Sep 17, 2007
R
roxtro
10
  • Sep 17, 2007
Where can I get step by step directions for changing these, can I replace them w/o taking control arms off...is there a tool i can rent where i dont have to take the control arms all the way off(press out-press in new BJ) if so who has it and what is it call. Id rather not replace CA's with new 03 or 04. Thanks
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Sep 18, 2007
  • Sep 18, 2007
The 03/04 Cobra A arm is the same A arm with a revised 99+ ball joint and a set of stiffer bushings. As far as I know there is no physical difference in the A arm itself.
Is your car lowered ? If it is, then I suguest these:
http://store.summitracing.com/partdetail.asp?part=FMS-M-3050-S&FROM=MG
If not then just use stock parts or use those and you can lower your front end 1/2 an inch.
There is a tool to do this service without removing the A arm from the car. It looks like this:
http://cgi.ebay.com/ebaymotors/BALL...010QQitemZ200151642603QQrdZ1QQsspagenameZWDVW
I would recomend yanking the coil springs just for safety when you are doing this.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 18, 2007
  • Sep 18, 2007
He is right. A-arm is the same, ball joints and bushings are better. You do not have to remove the springs of a arm. You can rent a tool that you use with an impact gun. It threads upward and pushes the baal joint out. It does the same thing to install it.
I recommend getting a Moog ball joint. I installed these in my 93 control arms. They are tight as can be, made in USA!!! and they have the grease fittings.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 18, 2007
  • Sep 18, 2007
Best thing for you to do is to get a Chilton/Haynes manual for your car, there is also a Disc you can download off of www.fordcds.com which is the Ford service manual. 99-04 years are practically the same.
the fordcds site is down for now so check periodically to see when it's up
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
