  • SN95 4.6L Mustang Tech
97 gt missfire problem
  • Thread starter Thread starter tri5333
  • Start date Start date Mar 8, 2009
T
tri5333
14
  • Mar 8, 2009
my 97 gt has a missfire at 4000rpm under heavy acceleration sounds like a popping sound. Mods are c&l cold air, c&l intake elbow other than that it is stock. The car has 61k miles and the plug wires were replaced by the previous owner with belden 8mm wires. The cel has not activated once and the car passed e-check no problem. Any ideas or suggestions would be appreciated.
schoffs4
17
  • Mar 8, 2009
It would be so nice if ford had misfire counters huh . How does it idle? if it idles with no misfire i would check for possible cracked valve spring if its poping sound your hearing.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 8, 2009
  • Mar 8, 2009
Probably 90% of misfires are spark plug & wires related. I had some top of the line Rousch wire one time that only lasted 2 years!
If you can do your own plugs, buy a new set, check the gap & use a torque wrench to set them. If that doesn't fix it, change out the wires.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 8, 2009
  • Mar 8, 2009
Is there any hesitation? If not then you may have detonation issues. A consistent misfire usually throws a code.
bhuff30
6,037
35
129
Olathe KS
Mar 8, 2009
  • Mar 8, 2009
A bit of a long shot, and definately consider the plugs and wires first... but you could try cleaning the wire in the mass air meter. It may be so lean at 4000rpm that it starts missing. Certainly, a pop is not normally found with an ignition miss.
NO BRAKES
129
Avon Lake, Ohio
Mar 8, 2009
  • Mar 8, 2009
im not sure about mod motor c&l maf's but ive not had any luck with em on push rod motors. maybe thats your problem.
schoffs4
17
  • Mar 8, 2009
Im saying possible valve spring because of his 4000k miss. Usually a plug or wire [usually the cause of a miss] will miss regardless of rpm or load. I found in the past with a overhead cam 4.0 with same issue miss under load the valve will float at high rpm because it cant fully close tight because of the spring cracked but run ok at lower rpm. Just something to look into. Your popping noise is what makes me think this. Good luck
mrvax
Mar 9, 2009
  • Mar 9, 2009
schoffs, whenever I've had a miss due to plugs/wires it seems to only happen under load, at higher rpms. If you take it real easy, you don't hear it. When you nail it, that's when the problem seems to occur.
Just my 2 cents.
Off topic: When are we supposed to replace the coil packs on our 4.6L ?I have 104k and they seem to be fine.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 9, 2009
  • Mar 9, 2009
I wouldn't replace them unless you were having issues.
T
tri5333
14
#10
  • Mar 9, 2009
  • #10
I just got back from driving it in the rain and it is actually worse. I dont want to randomly start changing stuff anyone with some suggestions?
mrvax
Mar 9, 2009
#11
  • Mar 9, 2009
  • #11
Spark plugs are cheap. Try them 1st.
T
tri5333
14
#12
  • Mar 10, 2009
  • #12
problem solved
Just installed ford motorsport fms-12259-r462 wires nothing else and it solved the missfire car runs better than it did before.Hopefully helps someone with similar problem.
T
tbird187
392
Indiana
Mar 14, 2009
#13
  • Mar 14, 2009
  • #13
I had the same problem today.. tried plugs first and it ran worse.... got new wires. and runs like a new car my wires were pretty new too
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • dan50
  • Jul 18, 2026
dan50
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
