Engine 97gt Cracked Valve Cover?
97GTSTANG
852
Virginia
Whenever I start the car, it looks like oil is dripping from the passenger side valve cover and after the car is warm smoke starts to come through the vent. I was told the valve cover might be cracked. If I purchase a replacement is it difficult to replace? Is it just to remove amd replace or do I have to have timing adjusted again?I just had the heads replaced last year and everything is set perfectly and car runs great.
bhuff30
6,037
35
129
Olathe KS
I'd say it is much more likely you just need to replace the valve cover gasket/seal. Unless someone cranked down the valve cover bolts too tight when the heads were replaced, I don't see the valve cover being cracked.. and that issue would have shown up immediately. So keep the cover handy and replace it if you want while everything is apart, but make sure you replace that gasket. The job can be a royal PITA since there is so little room between the shock tower and cover, but as I recall the passenger side has more room to work.
