This will be the third time my driver's side window regulator has gone bad on me. The first time, it was a broken arm on the regulator unit so I picked up a replacement (from a 96) on eBay and swapped it out.
8 months later,the regulator motor on that unit went. I figured it was my bad for picking up a used part. I replaced that unit with an AutoZone replacement. So now, about 12 months or so after installing the new regulator, my driver's side window is stuck down.
I can hear the click of the blue electronic module that auto-stops the window from going down when I hit down on the switch. And just for the heck of it anyway, I swapped the switches between driver's side and passenger side. I even tried the old ... slam the door shut while the switch is engaged and giving the unit a whack with a hammer.
So once again my door skin is off. Very frustrating.
Anyone know if there are any years that I can use to put in a manual door window system? Being the third time ... something has got to give here. Either I put in a manual system or the door skin stays off for good since I know I'll need to be in there annually.
Any advice or suggstions would be appreciated.
- Brian
- Brian
