Had my car out for first time in almost 2 weeks last night and now I have a problem. The car is 98 GT and is basically stock except for what's listed in my sig. I got on the highway after about 10 min of driving it. The engine shut off while I was going about 55 mph. I tried to turn the key while I was coasting but it wouldn't start so I pulled off to the side of the road. The car is getting power; all of the accessories work and the battery was replaced about 3 months ago. When I turn the key, the engine will turn over but it won't start. There is no check engine light and all of the gauges read normal. I changed the oil about a week ago but I don't see why that would cause this problem. The oil level is where it should be
Any ideas what this could be? Thanks in advance
I also forgot to mention that the car has some type of aftermarket alarm that the previous owner had installed. I had a problem with it going off for no reason when I bought the car about 9 months ago, but haven't since. I'm thinking this wouldn't cause the problem, because if the alarm was "tripped", the engine would not turn over when you turned the key correct? However the theft light did flash on and off really fast when I tried to start the car (I'm not sure if it always does that, never noticed it before if it does)
