98 GT fuel help, power adder a.s.a.p
Well my buddy happen to order all the wrong stuff for the car thinking its has the basic fuel system for the 97 and under GTs. So i couldn't even put it on the dyno to tune it. :nonono:
Does my 98 GT need a fuel pressure regular or is it controlled by the computer. I need a good site to get everything from and i need to next day it.
Stock GT with full exhaust, auto, with a D1sc procharger on 12psi.
I need: PART NUMBERS?
SVT Focus pumps
Boost a pump or pusher
Fuel pressure regulator????
IF someone can help me really quick thanks a lot. This fuel stuff on this 98 is confusing the hell out of me. Thanks a lot!!!
98 had both. just look on your fuel rail and see if you have a return line. if you do then you have a fuel pressure regulator. if not then your fuel pressure is contralled by pwm from the pcm.
