  • SVT Tech Forum
99-03 swap
  • Thread starter Thread starter Blk99SvtCobra
  • Start date Start date Apr 12, 2004
Blk99SvtCobra
68
  • Apr 12, 2004
what is the diffrence between a 99 and a 03
for swapping reasons
9
99SVTAddict
613
Clinton Twp, MI
Apr 12, 2004
  • Apr 12, 2004
Not sure, but it should be a pretty easy swap. I don't even think the computer would have to be changed. You could reuse the 99's tranny, but the flywheel would have to be changed out. I think that's about it.
Others will know more I'm sure.....
C
CobraCruiser
265
Toledo, Ohio
Apr 12, 2004
  • Apr 12, 2004
What are you planning to swap? Motors? Drive shafts? Transmissions? Cars?
Your platform is the same. I don't see any problem in changing over anything. You just have to use the other parts that work with the part you are switching, like changing drive shafts, etc, when you switch transmissions.
I would assume that you are swapping '03 stuff onto your '99? Other than seats, I would leave everything else alone on the interior. You have a much better audio selection with the '99. I am modifying my '03 dash so it can take the audio components like my '99 has. The '03 six disc changer basically blows. The Eclipse CD player and separate six disc changer in the '99 totally smoke it.
Good luck.
cerp
70
  • Apr 17, 2004
WELL?
I FOUND OUT A STOCK 99 COBRA TRANSMISSSION WILL BOLT UP TO AN 03 COBRA ENGINE MOST OF THAM INCLUDE THE FLY WHEEL.
STANG ADDICTS ON THE RIGHT TRACK.
M
Milehigh_Stang
17
Denver Colorado
Apr 18, 2004
  • Apr 18, 2004
I give up, why would you WANT to bolt up a 99 tranny to an '03 engine? The T-3650 isnt rated to handle the SC engines HP and will blow. Plus the fact that the T-56 is a 6 speed and worth every penny. You would be asking for trouble swapping out the engine without the transmission (and the other parts like cross member and drive shaft). My opinion.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
W
03 cobra shifter question
  • Wtupribs
  • Sep 7, 2025
  • SVT Tech Forum
SVT Tech Forum Sep 8, 2025
Wtupribs
W
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 1:32 AM
bjornsn95
  • SVT Tech Forum
