  • SN95 4.6L Mustang Tech
99 4.6 In a 97 Mustang gt. Possible?
  • Thread starter Thread starter stang acid
  • Start date Start date Jun 22, 2010
stang acid
  • Jun 22, 2010
I'm going to put my 1999 mustang gt 4.6l v8 motor and auto trans into my 97 mustang gt that also had a v8 and auto trans in it. I need to know what I would have to swap out to make this motor run in the 97 body. I know the computer needs switched. What else? Thanks!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 23, 2010
  • Jul 23, 2010
This should be in the "SN95 4.6 Tech" section.
Engine wise, what you are doing is basically a PI engine swap. Plenty of ppl have done it. This swap will be somewhat more complex because the 99 had a Windsor block and the 97 has a Romeo block. Have you searched?
Transmission wise, be advised that the 96-98 MY uses a VSS sensor. Where as the 99+ uses an output shaft sensor (OSS). The two sensor's output are NOT compatible with each other. Also, many of the Speedcal units do not work with an automatic transmission.
Also note that there it is likely that the digital transmission range selector (DTR) is different between the two MY.
It may be possible to transplant the VSS and DTR from the old transmission to the new. However, some dis-assembly will be required. For just how much, you should contact an transmission specialist.
Dark04GT
758
62
59
NC
Jul 26, 2010
  • Jul 26, 2010
It will be much cheaper to do the PI swap- swap the intake and cams and call it a day.
That is unless the motor needs to be worked over.
clentonz
26
  • Jan 7, 2011
edit
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
What changes need to be made to the brake system after swapping a V8 rear axel into a V6 1999
  • MARTYMAN
  • Jan 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 22, 2026
Mustang5L5
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
