99 Cobra
If you can get your stang in the high 12s you'll beat most of them. One dude had a stock 2002 Z-28 running 13.5s Another dude had same car with slight mods and drag radials running 13.0s.
Your putting down about 275 rwhp in stock trim. Get a cold air kit, underdrive pulleys, aftermarket exaust, sticky tires, 4.10 gears, quick throw shifter, a custom chip tune and you'll be around 308 to 315 rwhp.
why is it that the cobra is said to have 320 but you are all saying differently?
i plan to put 4.10's, cold air, and new pulleys on it this summer..i'll save the major mods for later
320 is a flywheel number, the cars actually put down, let's say, between 270 - 280 to the rear wheels, known as rwhp.
careful with 4:10's
I put 4:10's in mine and I dont know if that was the right move or not, I should of went 4:30's. Why you ask, here is what I have ran into, I can go approximatley 95 mph in second gear then I have to shift to third. Well guess what right at the line on the quarter mile I have to shift which can cost you tenths or maybe seconds depending on the shift. I figure if I went with 4:30's I could run the quarter in first and second and get better times. Dont get me wrong the 4:10's are a huge diffrent and they feel powerful specially in first. But just remember lot more shifting with the 4:10's. Think it through and if you get them let me know what you think
[email protected]
[email protected]
I've been hearing that a lot lately, go with the 4:30's. At first it was 4:10's, but now the 4:30's seem to be the favorite.
I'm wondering if that is to steep of a gear. My car isn't a daily driver, so I guess it could work. How do the 4:30's feel? Do you even start off in 1st gear? Are these for a mostly 1/4/track car? My car might see some 1/4 action twice a year, would that be to much gear for mostly around town driving?
On a side note, I bet you would tear up some camaro's and ta's with those gears
[email protected]
True, with higher gear ratio you have to shift more often. You gain quicker acceleration at the trade off of loosing top end speed. 4.10 gears is a good choice. Just curious though, stock gear of 3.27 in 99 cobra: 2nd gear tops out at 77mph. When you switched to 4.10 gears you should be shifting a lot sooner, way before reaching 95mph. With 3.73s, 4.10s or 4.30s you'll need to use 1st, 2nd, 3rd, and 4th gear to go the 1/4 mile if your tire size is close to stock. Otherwise you'll hit the rev limiter while in 3rd gear.
