Okay guys first post so not even sure if this is the right spot but I can not find an answer to this anywhere. I bought this car with the swap half way done. The problem I am having is converting this efi car to run a carb. I have read you can just run a bypass regulator from the original efi pump but since the 99-04 Is a returnless system that won't work. So would I have to rig up a return line?? How would I do that. Or if I put an external pump for a carb on could I just pull gas through the existing fuel pump or do I have to get rid of that and lose my fuel gage? So confusing any help is appreciated. Thanks
