Expired 99 Mustang With 5.4 Swap
Lee Icard
I am selling my 99 Ford Mustang GT. The car has around 145,000 miles on it. I love the car but really have no use for it anymore. I do not drive it too often. I have put 2000 miles on it in 3 years. The car does need to be painted because of a wreck 4 years ago. It was repaired by a professional body shop. It does have a salvaged title because of the cost of the wheels, body kit, and sheet metal damage that happened in the wreck. The integrity of the car is sound. It drives straight just needs to be repainted black. The car has loads of goodies on it. It has a complete Roush stage 3 body kit. It has Roush side exhaust kit. The front suspension consists of QA1 k-member, coil over drop struts, springs, caster/camber plates. The front brakes have been upgraded to cobra calipers and slotted/cross drilled rotors. The rear suspension is QA1 2.5 diameter springs with wolfe racecraft weld in upper spring perches. The rear brakes have been upgraded to a set of Bear 13" slotted/cross drilled rotors. The rear end has an Eaton true trac with ford racing 3.73 gears. The axles have been replaced with a set of Moser axles. It has an aluminum driveshaft. The mid pipe is an offroad h-pipe with ford racing shorty headers. The shifter is a B& M ripper shifter. Tail lights have been converted to sequential lighting. The head lights are HID. It has black FR500 18 x 9/18 x 10 wheels with 265/35R18 fronts and 295/35R18 rears. The wheels and tires are brand new. The current motor in the car is a forged Ford Racing GT500 5.4 short block with Trick flow 39cc heads. Head gaskets are Cometic with ARP head studs. The cams are a set of stage 2 modular headshop turbo cams. It has a HPS aluminum intake with BBK one piece plenum and throttle body. The motor has around 1000 miles on it. I installed a canton 7 quart oil pan on the motor when I installed it. Also the car has a custom tune for the 5.4.A wideband air/fuel meter is mounted on steering wheel and can be hooked into the programmer for datalogging. Included with the car is a SCT programmer that holds the stock computer program and the custom tunes that are in the car's computer. I can email pictures upon request. I am asking 7000 OBO.
