After recently going thru a mini monsoon, my 99 Mustang V6 just decided it didn't want to start anymore. I replaced the battery with no joy. When trying to start, everything appears to go as normal with the starter attempting to fire, but it won't turn over. After a little more troubleshooting, I realised it doesn't sound like the fuel pump is coming on. The Instrument Cluster Test gives me an Ignition Run Circuit Open (dtc 9356) code. Is there anything else I should check before dropping my tank and replacing the fuel pump. I believe I already need to just to replace the filler neck gasket (leak), but just want to cover my bases before replacing the pump. Thanks for any help you can give!
