99 power driver seat in a 94....
  • Thread starter Thread starter yellow86
  • Start date Start date Oct 5, 2004
yellow86
343
Vancouver BC Canada
Oct 5, 2004
  • Oct 5, 2004
they harness is different how to i make it work? the 94 has 2 wires and the 99 has 4... help out a dumb canadian
FiveLtrRiceEatr
197
Michigan
Oct 6, 2004
  • Oct 6, 2004
http://www.fordmuscle.com/archives/2002/03/interior/index.shtml
check out that article from Ford Muscle
I got 99 Roush Seats and I'm putting them in my 88 lx. But you can use the 99 and up seats in foxes and sn95s so I hope the article helps
trbkrb
1,976
Houston, TX
Oct 6, 2004
  • Oct 6, 2004
I suppose the two wires are a hot and ground in the 94. If so, then you just need to connect the two green wires in the 4 pin connector together for power, and the black one goes to the ground. The other one is for the seat belt buckle which you don't "need". If you are using the seat mounted buckle, you can wire it into the 94 seatbelt wiring if you want to.
Here is a pic of the jumpers I made for my seats. I used the round connectors on the seat side and spade ones on the car side, but I don't know what the 94 harness is like.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
94 kill switch wire question
  • MrPerfect2
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jan 10, 2026
fasterthangas
F
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
