A basic free mod check list
  • Thread starter Thread starter nickg42oz
  • Start date Start date May 26, 2005
  • 3
1 of 3 Next Last
N
nickg42oz
358
New Orleans, LA
May 26, 2005
  • May 26, 2005
I just wanted to start a thread about the free basic mods that can be done.
I'll start with Air silencer removed...........let the list begin.
Aliate X
602
Rockland NY
May 26, 2005
  • May 26, 2005
Remove front sway bar
Id consider AC delete pretty cheap. 41 bucks for the delete kit.
deadlast
495
Belmont, MA
May 26, 2005
  • May 26, 2005
sway bar on which car?
remove 25 lb weight (94-95) only
homemade ram air
Aliate X
602
Rockland NY
May 26, 2005
  • May 26, 2005
on pre 94 5.0s
C
Copperstang87
163
Thunder Bay, Ont
May 26, 2005
  • May 26, 2005
14* timing, short belt, remove airbox silencer(sum ppl say it helps other disagree)
G
grrrrrrr
289
norfolk, VA
May 26, 2005
  • May 26, 2005
Bump the timing, although, with the increase in gas prices maybe that isn't so free...
N
nickg42oz
358
New Orleans, LA
May 26, 2005
  • May 26, 2005
^^^^tuche`
A
Allforspeed
264
  • May 27, 2005
all weight reduction, index spark plugs, side gap plugs, some crazy people at the strip run their cars a quart low on oil and say it adds HP, but i wouldn't do it on the street, i guess thats pretty free also
Stang8URMPRT
1,100
Daytona Beach, FL
May 27, 2005
  • May 27, 2005
Throw your fat girlfriend out of the car while it's moving?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 27, 2005
#10
  • May 27, 2005
  • #10
Not free, but inexpensive...
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
*1.) I got a metal flange adapter from Powered by Ford for $35 and tax. That was over a year ago. Summit Racing may also have one too.
Powered By Ford
1516 South Division Avenue
Orlando, FL 32805
Hours 0800-1800
Phone 407-843-3673
http://www.poweredbyford.com/
deadlast
495
Belmont, MA
May 27, 2005
#11
  • May 27, 2005
  • #11
i never understood what the timing was. in what ways does it help and how does it work?
woodyy24
290
illinois
May 27, 2005
#12
  • May 27, 2005
  • #12
OL' WHITEY
273
Weddington, NC
May 27, 2005
#13
  • May 27, 2005
  • #13
Okay, deadlast. I'll try to explain. I'm feeling helpful today. Guys. don't flame me too bad. It's not the easiest thing to explain, okay?! Here goes...Timing is the relationship of spark to the position of the piston in the cylinder. Advanced timing causes the sparkplug to arc before the piston has come fully to the top of it's stroke (top dead center). Zero degrees timing is spark at TDC and retarded timing is spark after the piston has reached the top of it's stroke and is on it's way back down. To adjust the timing in a 5.0, loosen the distributor hold-down bolt and turn the distributor. Do this with the spout disconnected and point a timing light at the crank pulley. The pulley is marked. By turning the distributor, you'll find that you can advance or retard timing. Advanced timing adds a little power because if your spark happens before your piston has reached TDC, the piston more easily forces the spent gases out of the combustion chamber as it makes it's way up to TDC. Timing is set by the factory at around 10 degrees advanced. If you advance it further, you will be forced to run premium fuel to combat spark knock, but most stangers do it and feel that it's worth the extra price at the pump. I've had my timing up to as much as 17 degrees before with no pinging on 93 octane. I've heard that after about 14 degrees, you don't really pick up much more hp though.
Speeds8erM-1
1,240
Pensacola Florida
May 27, 2005
#14
  • May 27, 2005
  • #14
Remove Dog Bone, 9 pounds
Remove Sound Insulation in Hatch
Remove Sound Insulation Under Rear Seat, 6-9 pounds
TB Coolant Bypass
N
Niks93GT
47
#15
  • May 27, 2005
  • #15
Speeds8erM-1 said:
TB Coolant Bypass
I've seen this done. Why would you do it?
Nik
huRACEmentPSR
Banned
Apr 2, 2005
101
San Jose, CA
May 27, 2005
#16
  • May 27, 2005
  • #16
remove spare tire (espically applied to me...i went to 5 lug and had the 4lug spare still in 35lbs+)
remove gt fog light bracket (30lbs+)
^homemade ram air (funnel and clother dryer silver flex tube)
take out backseat (~35lbs)
Speeds8erM-1
1,240
Pensacola Florida
May 27, 2005
#17
  • May 27, 2005
  • #17
You bypass the tb coolant because it's just hot ass coolant heating your tb, feel the tb after driving it with the coolant hoses hooked to and feel it after you unhook it and drive it. It works. Must not have been needed, 93 Cobra didnt have it.
Stang8URMPRT
1,100
Daytona Beach, FL
May 27, 2005
#18
  • May 27, 2005
  • #18
Did you know that that coolant is there to COOL OFF the EGR (exhaust gas)?? Lemme think? 800-1200 degrees exhaust, or 200 degree coolant? LOL
Speeds8erM-1
1,240
Pensacola Florida
May 27, 2005
#19
  • May 27, 2005
  • #19
Oh hell, not this again! Here comes the debate! How come it's cooler with it off, how come it didnt come on the 93 Cobra after all those years of having it cast in the intake?
N
NUTCASE
187
#20
  • May 27, 2005
  • #20
I've herd against the coolant bypass unless you have the egr blocked off and you have an egr simulator. but I am temted to take the temp before, disconnect it, and take the temp after to see for myself and end all the debates
btw, whats the "dog bone"?
oh, and for my contrabution, when you go to the track try jacking up the pressure in the front tires to 45lbs. it ballons out the tire so you have less of a contact patch and therefore less friction to the road. this is perfectly safe at the track, I have done it on many different cars and I have been doing it for years. just make sure you remember to let the extra air back out when you leave the track and go back on the street
  • 3
1 of 3 Next Last
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
