A basic free mod check list
  • Thread starter Thread starter nickg42oz
  • Start date Start date May 26, 2005
  • 3
First Prev 2 of 3 Next Last
Stang8URMPRT
1,100
Daytona Beach, FL
May 27, 2005
#21
  • May 27, 2005
  • #21
The dog bone is the balance weight on the rear end. It doesn't really do anything. I took mine off the 83, and notice no ill effects. It bolts on to the front of the pumpkin.
M
Mean86GT
46
#22
  • May 27, 2005
  • #22
i have no ac, no smog, no rear seat, no spare/jack all misc stock bs plastic **** i deemed not necessary removed and came up to 3156 with a half tank of gas, me and a case of Dew.
N
NUTCASE
187
#23
  • May 27, 2005
  • #23
hmmmmmm........I thought that was to be some sort of vibration absorber
how much does it weigh anyways?
jb89coupe
416
CT
May 27, 2005
#24
  • May 27, 2005
  • #24
It is a vibration absorber, but it's tuned for the stock gears, so once you swap them out it doesn't do its job anyway. Some people will tell you 10 lbs.. but mine was rubber and weighed about 2lbs, if that. Maybe that was an ssp dealer option
EDIT: and aside from that, dead center on the axle is the last place you want to be removing weight.. focus on the front of the car.
N
NUTCASE
187
#25
  • May 27, 2005
  • #25
thats what I was thinking. but for 2lbs it just might not be worth it being I still have the stock gears
woodyy24
290
illinois
May 28, 2005
#26
  • May 28, 2005
  • #26
i took it farther than bypassing the coolant. i hooked up one of those koolers that have a pump built in, ran some lines to the TB and filled it with ice water. BTW i had an aluminum TB. now thats what i call a CAI.
N
NUTCASE
187
#27
  • May 28, 2005
  • #27
I thought all the 5.0 TB's were aluminum
besides, that sounds like a bit much for a handful of hp, I would rather concentrate my efforts elsewhere
The Fox
354
Port Elizabeth
May 28, 2005
#28
  • May 28, 2005
  • #28
Front Sway Bar
Rear Seats
Spare Tire/Jack
A/C and Smog Pump
Electric Fan
3g Alternator
TB Coolant Bypass
Shaved Body Hair/Take piss/remove penis/Clip toe nails
That last set of free mods WILL get you into mid 11s with a stock 302 depending on barometric pressure and which brand of high performance windshield washer fluid you use.
woodyy24
290
illinois
May 28, 2005
#29
  • May 28, 2005
  • #29
meant i had a 75mm TB and EGR plate. it was ice cold. and its not like i went and paid a bunch of money to do it. it was something i had laying around.
heres a pic. wish i took some better ones of the setup. but the cars gone now.
EDIT: the arrow looks like its poiting to the oil breather. but look below it. theres a white/clear line.
04sleeper
2,674
14
89
Dallas, TX
May 28, 2005
#30
  • May 28, 2005
  • #30
Remember when doing this to bolt the pinion snubber back on.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
May 28, 2005
#31
  • May 28, 2005
  • #31
The Fox said:
Front Sway Bar
93tealstang
1,242
McSherrystown/Hanover Pennsylvania
May 28, 2005
#32
  • May 28, 2005
  • #32
Originally posted by jrichker:
"94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes."
I'm not completely sure its a direct "plug and play." I tried running a 70mm meter with original stock electronics and my car really ran rough. I swapped over my 55mm electronics (which is a no no) to the meter and the car ran smooth and seemed completely normal. I'm totally against swapping electronics but in this case it seemed to work. Seems to me like maybe the electronics from the 70mm meter are not to friendly with the ECU. Can you explain or prove that the meter is compatable and is a direct swap?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
May 28, 2005
#33
  • May 28, 2005
  • #33
I am in the middle of a brake swap and I took my Dogbone off last night and it was metal with rubber bushings where the bolts went through up to the metal bracket that goes over the Diff. I did not have a scale in the garage but I can tell you it weighs more than 2 pounds!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
May 28, 2005
#34
  • May 28, 2005
  • #34
What Pinion Snubber?
T
TheUser
1,859
Springfield, MO
May 28, 2005
#35
  • May 28, 2005
  • #35
What car did you get your 70mm MAF from? The MAF needs to be programmed for the size injectors you have, so make sure to get one from a car w/ the same size injectors you currently have (stock=19lb).
Stang8URMPRT
1,100
Daytona Beach, FL
May 29, 2005
#36
  • May 29, 2005
  • #36
83's didn't come with pinion snubbers there. lol. And anyway, the pinion snubber is on the body pointed down.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
May 29, 2005
#37
  • May 29, 2005
  • #37
That is why that statement was baffling me, because mine is bolted up to the body above the rear axle assembly. Maybe he is trying to refer to something else.
D
DouglasOhio
116
Canton Ohio
May 29, 2005
#38
  • May 29, 2005
  • #38
I think what he meant was, when you swap the 70mm MAF to your 89-93, you reuse the 55mm electronics that were originally on the 89-93, like you figured out.
04sleeper
2,674
14
89
Dallas, TX
May 29, 2005
#39
  • May 29, 2005
  • #39
Sorry what I meant to say was to remember to bolt the bracket back on so snubber has a place to hit.
93tealstang
1,242
May 29, 2005
#40
  • May 29, 2005
  • #40
TTT for a reponse from Jrichker.....
  • 3
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Surging/stalling! problem or tune?
  • djj62478
  • Sunday at 1:53 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 11:37 PM
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
