A bend lower control arm?
  • Thread starter Thread starter bock
  • Start date Start date Jun 25, 2004
bock
648
Montreal,Qc
Jun 25, 2004
  • Jun 25, 2004
My car is lower on the back driver side then the passenger one.I changed the coils and it still the same.Can i have a bend or twist lower control arm?
A
autoXr1
1,838
Michigan
Jun 25, 2004
  • Jun 25, 2004
There are some springs that sit asymmetrically. That said, one has to mount them so that the coils sit on the spring perch identically, driver's side and passenger side. If not, then it may lead to different ride heights. If you haven't done so, check this.
You cannot bend the control arm. Doing so will shorten it. As you know, if one control arm is shorter than it's partner on the other side, it will lead to suspension bind and "dog tracking". If you are asking IF it could have a bend in the control arm, not likely, as the bend would have to be significant to create a ride height differential.
bock
648
Montreal,Qc
Jun 25, 2004
  • Jun 25, 2004
well, a mount them with the end of the coil pointing at the rear(both coils spring)They are stock coils
A
autoXr1
1,838
Michigan
Jun 25, 2004
  • Jun 25, 2004
Do a search on here regarding "lean" or "different ride height". There have been a few threads on this that I know of. Personally, I haven't had the issue with my car, but I do know that this is not uncommon. Perhaps you can find some information while searching the various threads on this site.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 25, 2004
  • Jun 25, 2004
Stock coils need both ends pointing to the passenger side (if I recall correctly). Right now you have one half installed higher and one half lower, I think. If you turn them, they should sit even.
bock
648
Montreal,Qc
Jun 26, 2004
  • Jun 26, 2004
both pointing the passenger side....
i went the way that was the lowered coil installed....
bock
648
Montreal,Qc
Jun 27, 2004
  • Jun 27, 2004
Well i finaly found in a haynes manual that both pig tail should point to the driver side... So i will try this, gonna a put some new lower isolator to...
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 27, 2004
  • Jun 27, 2004
I went out and checked my car, because I had questioned myself originally, and then I really did when you posted that you found this, and you're correct -- they do both need to face the driver's side. Sorry, my bad info (I suspected it was in my first post!). I still do think it will fix your problem.
bock
648
Montreal,Qc
Jun 27, 2004
  • Jun 27, 2004
i wich your right,cause if its not the coils, maybe the car is no more straight
bock
648
Montreal,Qc
Jun 29, 2004
#10
  • Jun 29, 2004
  • #10
Well,i reinstalled the back coils correctly and dont see much a difference...
Maybe they need a fiew rides!
Can it be the fact that the subframe connectors were install ,jacking a side and then the other side,and not with the 4 weels on the ground?
dastang2
2,020
tx
Jun 29, 2004
#11
  • Jun 29, 2004
  • #11
how old are the shocks, that could also be it, if one is a little worn out than the other then your car will lean most likely
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 29, 2004
#12
  • Jun 29, 2004
  • #12
Ugh...not a good idea. That could easily cause problems like that.
bock
648
Montreal,Qc
Jun 30, 2004
#13
  • Jun 30, 2004
  • #13
Ok, i found something else,the diff is not center. When i mesure the space beetween the tire and the fender,i found that the passender side tire is ¾ inch more outside than the driver side,the diff look like having moving toward the passenger side.
And,should i take off the subframe connectors,and reinstall them correctly?They are on the car for 3-4 years.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
O
Back in a Fox
  • Osorio299
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 25, 2026
gkomo
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
