a/c and p/s delete
  • Thread starter Thread starter TCullen
  • Start date Start date Jul 8, 2007
T
TCullen
28
West Chester, Pa
Jul 8, 2007
  • Jul 8, 2007
i'm running a 5.0 with a serpintine belt setup and no accesories except the alternator and waterpump. the trouble is that i've had to keep the a/c compressor and the 40 lbs worth of casted bracket only cause i can't find a suitable idler pulley and bracket for the top right side of the engine.
is anyone else here running a similar setup? is there a vedor or junkyard solution that you would reccomend that would help me ditch this heavy/ugly setup? thanks for your help...
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 8, 2007
  • Jul 8, 2007
Aside from getting one of those weird alternator tensioner setups I've seen on some built motor setups, the only solution I can suggest is to get an A/C delete pulley from UPR (or something similar) and use that as an idler with your P/S pump being gone - that way your belt has something to go over on that side and it keeps the belt tensioner functional. Looks ugly, but it's lighter than keeping the A/C crap, and it works.
KAILUAZ
333
St Pete, FL via Kailua, HI
Jul 8, 2007
  • Jul 8, 2007
Cant you ditch the serp belt and just go with a V-belt setup? Or would that require a reg rotation water pump?
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 8, 2007
  • Jul 8, 2007
That'd require some special brackets AND pullies, plus a different water pump.
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
V-1 Supercharger Belt Questions
  • kamikaze5.0
  • Mar 2, 2020
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2023
Superbrowndude
F
1990 Fox Mustang S Trim Supercharger Belt Configuration With No Ps, A/c, And No Smog
  • Fastr4d
  • Jun 17, 2015
Fox 5.0 Mustang Tech Jun 17, 2015
Fastr4d
F
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
N
Just Bought An 86' Gt *pics*
  • Nickster914
  • Jun 26, 2015
2K
Fox 5.0 Mustang Tech Jun 30, 2015
Nickster914
N
