A/C doesn't work anymore , needed help
Slow5.0
2,554
Portland, OR
Ok guys here is a deal
Last year I take out smog pump b/c bearing was bad so I put short belt without smog , than month later I put another short belt so I pass A/C , before my A/C was workin good , so with new short belt I passed A/C and every time when I turn knob for cooling/heating (thats know on right side) on mix , def , a/c norm and a/c max , high speed fan kick in, but not for long , for some reason I can't turn on high speed fan like 8 months now , but I already have switch for high speed in car so no problem for that ,
Yesterday I was thinkin why I don't put beck my old belt so I can have a/c for little bit , I installed but A/C clutch and high speed fan DOESN'T come on and air is normal , not coold like one with A/C on
So did anybody know whats wrong , I checked fuses and wires to A/C compressor but nothing
do you have power at the low pressure switch(on accumulator)??
with A/C on do you have power on other side of that switch??
if you don't have power on both side of switch then either you are low on freon or the switch is bad.
if you have power on both sides of switch do you have power at CCRM(pin #23 Bk/Y wire).
I have full charge of freon, but clutch and high speed fan does't kick on
Where is that switch "on accumulator"
Thanks cjones , but still nothing, I checked that switch doesn't look bad , only think is left and that is CCRM , meybe there is problem, Last months when I had some other problems I was tryin other CCRM , but high speed fan doesn't come on so "meybe" problem isn't there
1105 said:
yank it all out... you dont need it :D You live up north
I was thinkin about that but thing is on summer temp here is 90-100F and thats crazy b/c winter is bad too but the biggest problem is I like cruicing on highway and sometime I making long trips like 6 hrs to MI than I need A/C b/c I can't drive 6 hrs on hwy with top down and 80mph , wind gonna kill me and headeck too
Hey guys you don't have to buy new one from Ford dealer , you can go on junk yard and get one from 96-97 Taurus or Sable or 97 Escort or Tracer , they are all same but different numbers , I talk with my friend who work at Ford dealer and he show me that ours 94-95 GT Stangs have same CCRM and they sale under different number , I already try that like month ago when I have some strange problem with idle and with engine (turn out I had busted intake valve spring keepers,retainer and sleve on cylinder #4)
seth,
how much did the junkyard ccrm cost you? since my ac doesn't work, my freon is full, and i have power to both switches, the ccrm seems to be the only suspect left.
anyone know what they cost new from ford?
thanks
Hey guys, what is the ccrm? My understanding is power from the controls to the switch to some diode to the compressor. If I have power to the switch and not the compressor and the compressor is full, what is the culprit? Where is this diode?
I don't think you get me. I get no power (voltage) to the compressor. If I use a 12v source directly to the compressor, the clutch kicks on. The low pressure switch has power to and through it. Something is in between the low pressure and the compressor that is preventing from getting power. I don't know what it is though.
Anyone?
BlueOvalStangGT said:
ummmm....... you put the a/c back in your car? whatever i never got a tracking number or anything, did i just get scammed? Send me a PM letting me know when i should be expecting the a/c condenser and lines i bought from you to show up on my doorstep.
No way man, I send A/C parts on 22nd , and you supposed get on 25th
I tryin find you on aol mess but you was never online
Here is tracking # 1Z 183 X78 03 3822 361 0
