A/C Eliminator bracket
  • Thread starter Thread starter btsclan
  • Start date Start date May 28, 2008
btsclan
64
Seattle, WA
May 28, 2008
  • May 28, 2008
I want to know which is best for eliminating my a/c unit, should I get just an eliminator bracket w/ pulley or should I get a non-a/c power steering bracket. I with the a/c eliminator you would keep the same length belt and with the non-a/c power steering bracket you would get a smaller belt, which is better, pros cons? Longer or shorter belt?
Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,056
224
Massachusetts
May 28, 2008
  • May 28, 2008
The goal is to eliminate stuff and clean up the engine bay.
Also, less pulleys means less chance of something breaking on you.
Get the Ford Racing kit, which is basically the non-a/c accessory brackets
FrankenStang
Now, give me a damn CT!
4,461
70
129
Florence, Az
May 28, 2008
  • May 28, 2008
Word. That's the one I've got on my Capri. As soon as I can afford it, I'm replacing the A/C eliminator kit on my Notch with the Ford Racing one.
Blk91stang
607
North Brunswick, NJ
May 28, 2008
  • May 28, 2008
I'm a HUGE fan of the Trickflow setup. Cheap, $35, and takes brackets away instead of adding new bulky brackets like the Ford Racing setup. Looks a ton cleaner too IMO.
millhouse
1,985
Simpsonville, SC
May 29, 2008
  • May 29, 2008
IMHO, the cleanest way is the OEM way. The FMS kit includes a cast aluminum (lightweight) bracket that simply re-locates the power steering pump to the spot the a/c condenser once resided. This is the same bracket used on the factory a/c delete cars…so in theory, if you could find one in a junk yard you could pull it off an use it.
Every other kit I've seen not only ad's extra brackets (quite often steel), but also ad's extra idler pulleys which again…IMHO look tacky and out of place.
ram360
2,162
Pennsylvania
May 29, 2008
  • May 29, 2008
crazystang89gt
Coral Springs, FL
May 29, 2008
  • May 29, 2008
Ok now my question is, I have a Flamming River manual steering kit that I am putting on, and also want to delete my a/c. what a/c kit should I use. I am trying to find one, but coming up short.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
