  • SN95 V6 Mustang Tech
A/C or Voltage Problem?
  • Thread starter Thread starter mikevyota
  • Start date Start date Jul 5, 2007
M
mikevyota
9
  • Jul 5, 2007
I drive a 97' Mustang, 125k miles and recently the A/C starts cycling, the rpm's drop, the voltage gauge drops and the car bucks a little at the top of first gear.The idle always come back up right away, but sometimes it does this two or three times before settling down. Car is T-5 5-speed. Seems to do this only at extended idle and leaving a light. At cruise or on the highway, it doesn't miss.
The alternator is new, replaced yesterday. I checked it running, before it was only 13.2 volts, now it's 14.59 volts with all acc. on. The car only misses with the A/C on. The compressor, condenser, dryer are all on their second summer( Las Vegas heat, It was 116degrees yesterday!!!!), and only started doing this two days ago. Is there an idle "bump" switch for when the A/C is on? Or something else that I'm missing?
All help is appreciated!
raz54
205
Eureka Ca.
Jul 9, 2007
  • Jul 9, 2007
The IAC is what speeds up your idle when the AC is switched on. It may be sticking and still not trow a code. You can try to clean it with brake or carb cleaner.
M
mikevyota
9
  • Jul 21, 2007
I put a full charge on the battery, and the idle problem went away. Guess the A/C doesn't like to run without full voltage.
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Jul 21, 2007
  • Jul 21, 2007
You already had a full charge. Anything over 12v is charged. At 13.2 you still should have been fine.
Did you disconnect the battery to charge it? If so, you reset the compute and that most likely did the trick. The problem may come back, so keep an eye out.
M
mikevyota
9
  • Aug 16, 2007
Wow, that took a while for a reply. No, I didn't remove the battery, just drove the car til the new alt charged it back up. Have since sold the car way too much $$$.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine A/C QUESTION
  • Mindseye007
  • Jun 5, 2025
  • 2 3 4
2K
Fox 5.0 Mustang Tech Jun 22, 2026
nicholase
